Farmall Cub rim paint
Ferg
08-02-2006 12:40:46
Does anyone know the paint code and color for Farmall Cub rear rims? Thanks
GordoSD
08-04-2006 07:58:40
 Re: Farmall Cub rim paint in reply to Ferg, 08-02-2006 12:40:46
Your local IH dealer should have "Argent silver" also. It's a gray metallic that looks great.
GW
B-maniac
08-02-2006 20:03:34
I believe Eastwood Co. has a simulated galvanized paint.A freind of mine used it on a Farmall "M" an just the rims and it looks good. It lays on thin and wet so the flake "mottles" and gives it the flaky galvanized look.Don't know the name of the paint. Look up WWW.eastwood.com I believe it's 10030z Tank Tone Metallic Coating. It's to restore auto fuel tank exteriors and looks like galv. The coating contains zinc. Hope this helps.
B-maniac
08-02-2006 20:03:24
CNKS
08-02-2006 17:05:42
There isn't one because the rims were galvanized. You can use aluminum, silver, or silver argent paint, whatever suits you. I use PPG 8568, sort of a silver argent paint that has a little gray in it. It is a GM rally wheel color. Since the rims were galvanized they were not bright when new.
