ZXB Hercules Engine for Avery Tractor
Redtractorman
09-07-2001 09:05:04
Can anyone tell me if a ZXB hecules engine will fit in an Avery Model A or V Tractor
Keith Ault
09-17-2001 08:45:52
 Re: ZXB Hercules Engine for Avery Tractor in reply to Redtractorman, 09-07-2001 09:05:04
Military applications of the Hercules engine used a flywheel that had a taper on it instead of a straight surface.One must be carefull,as you will either break the crank or the flywheel when you torque it down ka
Jim Forsyth
09-11-2001 10:34:04
Beware! Not all ZXB's will fit in the "V" The ZXB from military generator sets and some fire pumps was counter clockwise rotation. They are usually stamped on the head "CCW". A ZXB5 has a different timing cover and usually a waterpump and Mag combination. They are to wide to fit the frame of a "V", but can be changed back to a ZXB3 and used. Good luck !
Larry from Maryland
09-07-2001 09:07:00
It fits a V.
Bob
09-10-2001 09:12:39
 Re: Re: ZXB Hercules Engine for Avery Tractor in reply to Larry from Maryland, 09-07-2001 09:07:00
My V has a ZXB3 Herc.
