Devere lawn mower
Bruce
02-09-1999 11:06:27
I inherited a 30" walk behind commercial lawn mower of which I have never heard of, nor seen another like it. It is powered by a 9HP, horizontal shaft Wisconsin engine, that more times than not, starts on the first pull from the manually wound rope. The blade is turned via a 2"wide flat belt that makes a 90 degree turn on 2 idler rollers that also act as the blade clutch. The self propelled wheels are driven from a transmission on the right side which bring me to the problem. The clutch disks are worn out & I need to find a replacement.
Has anyone ever heard of this beauty?
Thanks to anyone who can help w/ any info.
Virgil Hurley
04-10-1999 14:36:21
 Re: Devere lawn mower in reply to Bruce, 02-09-1999 11:06:27
I have a friend who has a devere lawn mower and has the same trouble you have. Please let me know if you find any replacement disc or pads.
Gary Hearn
02-09-1999 19:17:14
Bruce,
You might want to contact an automotive machine shop to see if they could reline the disks for you. I have found that this is almost always cheaper than finding new parts and you know that the parts will fit!
Sorry I can't help you with the origin of your machine.
