Suzue 1504wd pistons
j. a. merkey
02-07-2000 18:25:40
i need a piston for this tractor and my local dealer has none. any help would be appr.
small import tractor paul
02-10-2004 22:19:50
 Re: suzue 1504wd pistons in reply to j. a. merkey, 02-07-2000 18:25:40
we have pistons std and oversize plus all other motor parts
Ray
04-13-2000 07:21:53
I own a Suzue M1803D 4 wheel drive tractor. My brother saw the 3 cylinder diesel engine in mine and said he thought it looked identical to an engine John Deere is or was using. You might take one (piston) down and see if they can match it. We speculated that the "18" in the model indicated horsepower; therefor yours might be a 15 horse model. I would like to get any and all information about my model or Suzue's in general. What country are (or were) they made in? Can new parts be obtained and from who? Can someone photocopy a manual for me (I would re-emburse expenses)? The parts I need are shift boot, and axle seals (rear). Automotive machine shops have sources for pistons, also. Check several. Pistons can sometimes be saved, depending on the severity of the damage. If it just doesn't fit the bore anymore, it can be "diamond knurled" to swell it up to about .020" oversize. It must be hand fitted after knurling.
J. Dotson
03-21-2000 18:21:29
Try Willamette Exporting. Phone;503-246-2671. I'm trying to find a used steering assy. for a Suzue 170. Good luck. J. D.
