Lesser Known Classics Discussion Forum
Long 460 or 445 ?
Josh Bradberry
03-28-2008 18:12:41
This message is a reply to an archived post by Ronnie Eberts on April 24, 2006 at 13:15:50.
The original subject was "Long 460 or 445 ?".
How do you get the starter off of a 460 Long?
Dwayne Berry
02-16-2009 18:31:58
 Re: Long 460 or 445 ? in reply to El Toro, 03-28-2008 18:12:41
I would think if it would turn over with a screwdriver then the problem lies elsewhere?
Pycoed
03-30-2008 16:38:15
 Re: Long 460 or 445 ? in reply to Mark Randle, 03-28-2008 18:12:41
If I understand it, the 460 is the 4 cylinder version of the 3-cyl 445? (Which I have)
On the 445 there are the usual 3 bolts - the back lower one is awkward to get at unless you have a 17mm obstruction spanner(wrench in American!).
Some original fitted starters on the 445 may not clear the rear hydraulic pump (power steering I think), so may need the pump removing to gain clearance (mine was OK). I wouldn't have thought there'd be a problem with a 4-cyl block.
Dsl
04-01-2008 07:20:30
 Re: Long 460 or 445 ? in reply to Pycoed, 03-30-2008 16:38:15
The 460 is a newer version of the 445. It has all the same mechanical specifications. It is distinguished by squared-off sheet metal, and headlights in the grille.
Removing the starter sometimes requires removing the power steering pump.
