Lesser Known Classics Discussion Forum
Thermostate on 610 long diesel
Larry59
01-23-2008 05:44:06
The tractor supplie said the thermostate is on back order and they have no idea when or if I can get one for this tractor. ... Tractor is 64 hrs diesel UTB motor. I need to know if another thermostate might fit it.. if so! What degree is it. ... My thermostate appears to be square like box with upper hump that fits on top. 4 bolt holes. Thermostate is gone from this one and can not measure are see if it fits downward inside are what.
Leaky Boot
01-24-2008 07:59:51
 Re: Thermostate on 610 long diesel in reply to Larry59, 01-23-2008 05:44:06
Where are you in MO? Brown Tractor in Bolivar has a pretty good parts stock. Might have what you need. Of course--maybe that"s where your going-----LB
Jim in NC
01-24-2008 04:29:21
Larry, you can go to Farmtrac.com and search for a dealer near you. Farmtrac is the new name for Long. You could also take your old thermostat and radiator hose to a auto parts store, and a good parts person can match your thermostat and hose to one that will work. You may have to buy a longer hose and cut some off. I have done these things before.
Larry59
01-24-2008 06:07:04
 Re: Thermostate on 610 long diesel in reply to Jim in NC, 01-24-2008 04:29:21
Went to napa and another auto parts store.. no hose was twisted the right way to use. Had to order it in threw a farmtrac dealer. However it has been two weeks on the thermostat and all they say is... it's on back order and hard telling when it will be in.... can't take old thermostat in to compair for the tractor had none in it. Thanks
Jim in NC
01-24-2008 09:54:45
 Re: Thermostate on 610 long diesel in reply to Larry59, 01-24-2008 06:07:04
Larry, one more for you. Try searching "Fiat-built tractor parts."
El Toro
01-23-2008 09:46:10
Have you tried Napa? You will need the engine model number they should have a thermostat to fit.
Call 606-849-2677 in KY and see if they have a thermostat. Hal
Larry59
01-23-2008 12:35:35
 Re: Thermostate on 610 long diesel in reply to El Toro, 01-23-2008 09:46:10
Have not tried them. Did try them on a top radiator hose and they did not have nor could get it for me. I am in Mo. .
