Lesser Known Classics Discussion Forum
Ferret tractor
Jon Jacobsmeyer
10-16-2007 14:06:41
This message is a reply to an archived post by To Dale C on August 16, 2004 at 12:25:38.
The original subject was "Ferret tractor".
I bought one in Boise, Idaho for $800 and brought it home to my little ranch in Heber, Utah. I started it yesterday using starter fluid but it had fuel problems so I gunked the carburator and found out that the float valve was missing so I'm in the process of trying to find a new float valve or get a new carbuerator. I want to weld together a small "Tank" body so my grandkids can have fun with it. Jon
noncompos
10-16-2007 20:55:30
 Re: Ferret tractor in reply to Jon Jacobsmeyer, 10-16-2007 14:06:41
Unless that has an unusual float, floats generally just control fuel level in the carb by rising with the fuel, with a tab on the float pushing the needle valve (gas inlet ) closed...that's a long winded way of saying probably any float that fits the mount in the bowl, with a tab that can be bent to close the inlet, should work, assuming replacements hard to find.
