Lesser Known Classics Discussion Forum
Long 445 fuel leak
treeman
07-16-2007 11:10:59
Help. I have a fuel leak at my injection pump. I'm pretty sure it is at the output connection that feeds to the fuel injector. My parts book shows two gaskets, P/N TX11606. My closest dealer doesn't have this part and his computer doesn't show the P/N. If anyone is close to a dealer that may have this part let me know. Or, if you can obtain and mail parts to me I will pay for parts and shipment. thanks.
RMinVa
07-18-2007 18:24:20
 Re: Long 445 fuel leak in reply to treeman, 07-16-2007 11:10:59
Treeman you can give my Farmtrac dealer a call here in Va. I just got several of those type washers from him for the control hydraulic valve on a 2610 Long. That part no. is good. He should be able to get those from Farmtrac and mail them to you. They may drop ship direct to you also.
Ratliff Service Center
South Boston Va. 434-575-5954
John Lloyd
07-18-2007 14:07:11
If you can't get the washers, try annealing the old ones. Heat them to red with a blow torch & that'll soften them up. Drop 'em in some water after heating to speed handling. Works a treat with sump plug washers, I know the injection pressure is greater, but its worth a try if you can't get new seals.
treeman
07-16-2007 17:57:49
Would they recognize the Long P/Ns? These gaskets are copper washers to make a seal. I don't want to remove the washers for measurements until I have new ones in hand.
El Toro
07-18-2007 08:36:33
 Re: Long 445 fuel leak in reply to treeman, 07-16-2007 17:57:49
Give them a call and see if they recognize the part numbers. Copper washers are used on brake
hoses that are used on brake caliphers and most auto parts stores have a large assortment of washers. Hal
El Toro
07-16-2007 11:44:02
Call RealDiesel at 1-888-349-9461 to see if they have the parts you need. You can try EAU Claire
Diesel too at 715-835-1498. Hal
