Lesser Known Classics Discussion Forum
long 460 fuel filters
ironhead
05-14-2007 15:11:54
what is the correct filter for this tractor. we use a delphi 296 hdf296. just not fitting right. thats what the dealer sold me.
Bus Driver
05-19-2007 10:35:27
 Re: long 460 fuel filters in reply to ironhead, 05-14-2007 15:11:54
I did a bit more research. The original filter probably was CAV 7111/296. If that is correct, then Fram C1191A is a replacement. Ford DONN9176B and Massey 1851890M1 are other numbers.
Bus Driver
05-18-2007 16:36:22
The existing filter will almost certainly have some sort of ID on it. If the tractor has the CAV injection system, the filters for many Massey and Ford tractors should fit. Yours probably has two, identical to each other. Take the old one with you and look for one to fit a 135 Massey. Compare the old and new.
Jim in NC
05-14-2007 19:51:33
3166 at NAPA.
El Toro
05-14-2007 16:36:21
Hastings fuel filter FF963 should fit too. Hal
El Toro
05-14-2007 16:22:33
The Wix fuel filter number is 33166 for the 460 with the D124 diesel engine. Hal
PS: Napa may have it.
