Lesser Known Classics Discussion Forum
deutz 30 06 good tractor?
deene
05-11-2007 21:09:11
found one for sale runs well he said and has had transmission work and pump work turned to about 52 hp he says..what are the problems with these tractors?...he says you cant use them to pull a lot with because of bearing problems but i just want it to brushhog with...any things i should look for..thanks for any replies
deene
05-13-2007 19:55:33
 Re: deutz 30 06 good tractor? in reply to deene, 05-11-2007 21:09:11
this tractor is a 3 or 4 cyl and seems too run well but he said that he had to repair trans because plowing or heavy pulling messed up the roller bearings instead of having other bearings?..i dont know lots about them just what i have read on here and would like to upgrade to a diesel with power steering if this tractor would be ok...thanks for the help and replies
Bernhard
05-15-2007 03:42:49
 Re: deutz 30 06 good tractor? in reply to deene, 05-13-2007 19:55:33
Oh, yes the 06 range had been very good tractors. They don�t go for cheap in europe and You see heaps of them around on famrs, 30 years after the end of the 06 range.
Bernhard
05-15-2007 03:40:32
The engine of the D 3006 is a Deutz F 2 L 912, a 2cylinder.
Smallest tractor with 3cyl is the D 4006, with a F 3 L 912.
4cyl starts on the D 5506 (52hp), it�s the F 4 L 912.
Bernhard
05-13-2007 12:01:56
52 hp is rubbish, for that it must be a D 5506. D3006 has 30 hp and is a 2cylinder. Bearings are metric, so maybe impossible to get in the states.
For normal you can buy every tractor of the Deutz 06 range.
