Lesser Known Classics Discussion Forum
Long 445 Hard starting?
dej(jed)
05-01-2007 07:19:57
I have a good running Long 445. It seems to have to crank for a long time to start. Also there is a fuel leak from behind the injector pump. Any ideas would be appreciated?
Jim in NC
05-04-2007 04:50:56
 Re: Long 445 Hard starting? in reply to dej(jed), 05-01-2007 07:19:57
I would look for a fuel leak at one of the injector or fuel lines or connections and try to tighten it. Be careful and don't force it too much. It may be sucking air which will make it harder for it to start. These Longs will start easier the faster you turn it over. You need a good battery, connections and a properly working starter. It helps to have good, clean fuel. Open the drain on the botton fuel filter to drain and see if you have a lot of water there. If so ,you probably need to change fuel filters. Hope this helps.
