Lesser Known Classics Discussion Forum
three point hitch problem
Richard Laurier
01-24-2007 15:26:28
Have a 1365 Cockschutt and since the cold weather the three point hitch will not power itself. Can't raise it! If there is ice developed in lines or pump, how do I correct this problem.
Hard Knocks
01-25-2007 05:29:53
 Re: three point hitch problem in reply to Richard Laurier, 01-24-2007 15:26:28
Pick a day when its been above freezing drain the trans and rear also take off the cover of the filter screen in the hydraulic intake line.
Pull the screen out and throughly clean it with carb cleaner or something similar,put a new 'O' ring on when you replace the cover.Refill with a good grade hydraulic oil I use JD Hygard in my Fiats.Also make sure the gear shift lever boots are in good shape the boot that goes on a 2350 JD
will work do not use the 'O' ring around the bottom they are a little big at the bottom but will shed the water just fine.If you still don't have hydraulics plug in an open ended fiting into the remote line and hold the remote lever in pump
position until the air is purged and fluid starts to come out.Also I overfill the trans by
a half gallon or so helps keep air out of the system
