Lesser Known Classics Discussion Forum
Lanz Flywheel Covers
Molinegb
12-21-2006 17:22:05
I have three flywheel or clutch covers for Lanz Bulldog. They are 22 inches across. All have imprints which I believe you used to start by hand. Two have three mounting holes and the third has four along with larger center hole. Anybody have any ideas which model they would have fit?
Patrick Coxall
01-13-2007 10:21:10
 Re: Lanz Flywheel Covers in reply to Molinegb, 12-21-2006 17:22:05
There are number of Lanz and Lanz John Deere tractors that use this sort of flywheel cover/handstart ring.
I have a Lanz 5506 and Lanz JD 2816 both of which have these "covers" but I have a number of friends who are looking for such things.
Would you be prepared to sell them to me so I maybe distribute them to my friends in need.
Pat
Lanzboy from Aus
12-21-2006 23:44:51
Sounds like they're hand wheels off either a 1950+ N, P,or S.The 2 with the 3 mounting bolts sound right but the one with 4 could have been adapted to bolt onto somthing else, my guess an earlier n p or s with the larger shoe clutch or early plate clutch, wich would explain the larger center hole, for the end of the crankshaft to petrude through, dont quote me though.
Good luck and all the best for xmas,
Lanzboy from Aus
Molinegb
12-22-2006 05:33:41
 Re: Lanz Flywheel Covers in reply to Lanzboy from Aus, 12-21-2006 23:44:51
Thanks for the help. Do they have any value? I was going to put them on Ebay as they are no use to me.
Lanzboy from Aus
12-27-2006 22:34:51
 Re: Lanz Flywheel Covers in reply to Molinegb, 12-22-2006 05:33:41
i coiuldnt honestly tell you what theyre worth as generaly if a tractor was fitted with one then they usually remain on. one would think theyd be worth something but i cand honestly tell you a value.
regards Lanzboy
Bernhard
12-29-2006 08:43:48
 Re: Lanz Flywheel Covers in reply to Lanzboy from Aus, 12-27-2006 22:34:51
I would say their value isn�t more then 20$, cause they belong to a small semi diesel and not to a bulbhead. Remakes of this parts are easy to get new, in some parts of the world.
