Lesser Known Classics Discussion Forum
Oil Bath Air Cleaners
Larry White
11-03-2006 05:30:28
I am restoring an Avery V. Should the oil bath air cleaner have anything other than oil in it? I thought there should be some sort of fiber inside the canister along with the oil.
Larry
Larry from md
11-03-2006 14:36:48
 Re: Oil Bath Air Cleaners in reply to Larry White, 11-03-2006 05:30:28
There should be a wire mesh above the oil.The wire should fill the upper part of the canister.I have seen them removed and it makes the filter allmost worthless.
Larry White
11-03-2006 16:25:33
 Re: Oil Bath Air Cleaners in reply to Larry from md, 11-03-2006 14:36:48
Is the wire mesh something that is available at parts supply stores?
135 Fan
11-03-2006 19:59:11
 Re: Oil Bath Air Cleaners in reply to Larry White, 11-03-2006 16:25:33
I just read that you can change it if it gets a bunch of grass or something in it. I can't remember if it was in a manual or not. It said you could buy the new mesh for the filter. Check with a dealer. Dave
Gene Davis (GA)
11-03-2006 19:40:34
You can se the "Chore Boy" copper pot scrubbers if you press them down by hand only and remeber to keep them washed out when dirty. People sometimes ripped out the wire mesh in these cleaners instead of washing it.
