Lesser Known Classics Discussion Forum
LC HUBER Starter question.
Josh Wilhelm
10-21-2006 15:21:45
Hey HUBER guys I have just bought an LC that i'm going to fix up. I have heard that you can put a starter on this tractor. Is that true where do I find the parts? Or can this be done to one that never came with a starter. Any info would be great THANK YOU.
Jeff Wenner
10-25-2006 07:17:01
 Re: LC HUBER Starter question. in reply to Josh Wilhelm, 10-21-2006 15:21:45
My 39 L had a ring gear on the flywheel and was drilled and tapped for the starter. Found one off a 50's GMC truck that bolted right up and works great.
Josh Wilhelm
10-28-2006 15:22:58
 Re: LC HUBER Starter question. in reply to Jeff Wenner, 10-25-2006 07:17:01
Hi Jeff can you tell me where they located the starter on the tractor. I have some Olivers that use the same motor as the l&lc. My 80 Oliver standard the starter goes through the frame on the magneto side. These tractors share an identical frame but not exactly the same. Thank you Josh
Jeff Wenner
10-31-2006 07:14:03
 Re: LC HUBER Starter question. in reply to Josh Wilhelm, 10-28-2006 15:22:58
The starter should be in the same location as your 80. I have seen other Hubers that just had a plate covering the hole. I thought all the bell housings were cast like that, but maybe the older ones were not.
Josh Wilhelm
10-31-2006 14:46:53
 Re: LC HUBER Starter question. in reply to Jeff Wenner, 10-31-2006 07:14:03
Thank you Jeff that info is good to know thanks Josh
Kirk in PA
10-23-2006 17:51:01
Hi Josh:
I'm sure that you could put a starter on a LC, but I think that it would be tough. I have a '39 L with no electric starter. It has a hole for the starter, but no holes for the fasteners. The bigger problem is that the flywheel is not geared for the starter. I'm towards the end of restoration. I don't mind hand starting the 334 cu.in. Huber after years of hand starting the 511 cu. in. Allis.
