Lesser Known Classics Discussion Forum
long 510 brake adjustment
mark fennell
08-01-2006 16:19:55
My 510 brakes work fine when i use the parking brake lever with little effort but i press as hard as i can on the foot pedals and it just slows the tractor(clutch engaged of course). The pedals are adjusted even and contact is at half pedal. Is the brake worn out or is there a linkage problem. thanks
geok
08-01-2006 19:34:08
 Re: long 510 brake adjustment in reply to mark fennell, 08-01-2006 16:19:55
Sounds like either you have a oil leak on your brake bands or your bands or worn down to the rivet heads.
mark fennell
08-02-2006 08:12:12
 Re: long 510 brake adjustment in reply to geok, 08-01-2006 19:34:08
Why does the parking brake stop the tractor so easily? I just hold the button in and brake as needed by hand. Thanks
SamC
08-08-2006 18:07:29
 Re: long 510 brake adjustment in reply to mark fennell, 08-02-2006 08:12:12
Mark,
I don't know the 510, but my 560 Long manual shows two types of parking brakes. One style simply engages both foot brakes. The other style appears to engage a different, separate brake (my 560 has the style that uses the foot brakes).
Sam.
