Lesser Known Classics Discussion Forum
Leyland 344 Info wanted
Mike Gibson
03-27-2006 13:13:00
Hello,
My wife and I are looking at buying some property. On it, the owner's deceased husband left his tractor and she's interested it selling it with the property. It is a Leyland 344 in good overall condition. I can't seem to find any info on the internet about this tractor. Can someone tell me what the HP rating is on these??? Any other info, especially value (w/bush hog and sickle bar mower) would be greatly appreciated. SER# 44N/30272x/Z
Thanks,
Mike
L.D.W.
03-30-2006 20:46:50
 Re: Leyland 344 Info wanted in reply to Mike Gibson, 03-27-2006 13:13:00
55 hp is right, if its in good shape, with the attachments, value about 5500.00, no more though. They are a good machine, start great, and run very economical. Parts are still plenty available, if you need anything, I sell parts and repair them.
trakterguy
05-02-2006 23:50:56
 Info on Nuffield 3/45 wanted in reply to L.D.W., 03-30-2006 20:46:50
Hi,
Looking for info on a 1967 - 1969 Nuffield 3/45..I have had little luck finding anyone that still has one of these units...if anyone does plz respond
speedbuf
05-20-2006 04:09:59
 Re: Info on Nuffield 3/45 wanted in reply to trakterguy, 05-02-2006 23:50:56
hello parts and info are no problem ! There are lots around what do you need to know?
Trakterguy
03-14-2007 12:52:15
 Re: Info on Nuffield 3/45 wanted in reply to speedbuf, 05-20-2006 04:09:59
I have lost the clutch in my unit and now think I either need someone to service it or to sell the entire thing. Any leads??
speedbuff
04-01-2007 07:29:15
 Re: Info on Nuffield 3/45 wanted in reply to Trakterguy, 03-14-2007 12:52:15
where are you located ? what happened did the clutch go all at once or slowly start slipping? they are easy to fepair with only a small amount of mechanical skill required parts are no problem new or used
MJ in the UK
03-28-2006 06:25:05
Hallo Mike. Your tractor was made at Bathgate Scotland here in the UK from 1970 to 1972. It has a Leyland four cylinder 55hp diesel engine. Good reliable tractors with no fancy gimmicks to go wrong also good starting engines. MJ
H Kruger
06-08-2007 02:37:01
 Re: Leyland 344 Info wanted in reply to MJ in the UK, 03-28-2006 06:25:05
Hi I'm south Africa. I have Leyland 344 and will like to know where i can buy the following parts for the tractor.
1 Sleeve and piston kit
2 Main bearings
3 Overall gasket set.
Thanks Hannes Kruger
JV3CII
06-08-2007 10:11:44
 Re: Leyland 344 Info wanted in reply to H Kruger, 06-08-2007 02:37:01
Hello Hannes.
It might be worthwhile to have a look at the link below. If there is a club in your area, then they might be able to point you in the right direction for spare parts. There is also a messageboard which might also answer your question.
I hope this is helpful to you.
Best of luck (and keep us posted)
Cheers, JV.
Charlie Jones
08-26-2007 09:32:51
 Re: Leyland 344 Info wanted in reply to JV3CII, 06-08-2007 10:11:44
When replacment of clutch on a Leyland 344 can it be replaced with out spliting tractor (like the olivers)?
