Info on a Brockway farm tractor
Nellie
10-15-1998 18:27:49
I am looking for information on a farm tractor that the Brockway Co. (Cortland NY) made. I know they made truck tractors. A friend of mine is restoring a Brockway truck. He would like to find out about the tractors Brockway made.
Thanks, Nellie
JAMES SCHAFFER
09-13-2003 17:29:38
 Re: Info on a Brockway farm tractor in reply to Nellie, 10-15-1998 18:27:49
third party image
RESTORABLE TRUCKS FOR SALE
ONLY 3 DAYS LEFT #1 1969 BROCKWAY TANDEM TRACTOR RESTORABLE Item number: 2431639353 On ebay 1969 BROCKWAY TANDEM TRACTOR 48 REARS V8 CUMMINS 10 SPEED ROAD RANGER 10-22 TIRES (DECENT) DUAL STACKS NEEDS VERY LITTLE WORK TO RESTORE
#2 Item number: 2431637099 1960 RESTORABLE MACK 1 1/2 OR 2 TON TRUCK 6 WHEELER 10-20 TIRES 40,000 REARS 5/3 TRANSMISSION OIL TANK CAN BE REMOVED
Clutch
10-27-1998 20:47:24
: I am looking for information on a farm tractor that the Brockway Co. (Cortland NY) made. I know they made truck tractors. A friend of mine is restoring a Brockway truck. He would like to find out about the tractors Brockway made.
: Thanks, Nellie
Nellie, The only info I have on Brockway tractors is from A company in Ohio.I'll just quote you the paragraph. (The Brockway Tractor Co., Chagrin Falls, Ohio entered the market with three 4-wheel tractors with adjustable treads front and rear. Forward speeds were from 1.75 to 10 m.p.h. The Brockway 49G burning gasoline (page 54) had 24-28 hp. capacity, the Brockway 49D was powered with a diesel engine and capable of pulling 2 bottoms, and the 49K had the same specifications as the 49G but fitted with a kerosene engine. Hydraulic lift and combination power take-off and belt pulley were optional with either model.) Thats all I have, hope it helps--- Clutch
Nellie
10-29-1998 18:38:39
 Re: Re: Info on a Brockway farm tractor in reply to Clutch, 10-27-1998 20:47:24
: Oh yes this helps alot, My friend thanks you also. He said this makes his life alot easier. He was going to continue working on his Brockway truck and not have to worry now about finding a tractor to fix up to. Thanks for the Info. Nellie
