Lesser Known Classics Discussion Forum
UTB clutches
Bus Driver
01-04-2006 16:51:34
The smaller UTB tractors include the Long 350, 360, 460, 445, the Allis 4050, and at least one model of Oliver. Mine is a Long 360, bought new in February 1978. About two years ago, mine began to require increasingly longer clutch pedal travel to release the transmission clutch, with the result that pedal travel was insufficient to release the PTO clutch at all. The outside linkage from the pedal to the outside arm plus the clearance between the fingers for the PTO clutch accessible through the side cover are the only adjustments I have found without splitting the tractor. I have Owner's and Service manuals plus parts catalog. I took the tractor two years ago to a former Long dealer that I trusted who had always treated me well. His repair seemed superb. Reasonable price also. Told me some parts had come loose on the clutch pressure plate. Now, about 100 operating hours later, it is doing the same thing again. Is this typical of these tractors? Do you know any way to do a lasting repair?
geok (GEO)
01-09-2006 19:31:23
 Re: UTB clutches in reply to Bus Driver, 01-04-2006 16:51:34
Nothing comes to mind. I have only done a few back when. I don't recall any having problems after we did clutch replacements. Did your former dealer say what was coming loose? Do you use your loader a lot or just now and then? Usually what makes the adjustments change is the disc faces wear down quickly. If is possible that your clutch facings were of poor quality. I just did a repair on a MF 65 industrial after it was done by another fellow. First I couldn't really find anything wrong until I compaired clutch disc. The new one that I put in was thinner than the old one I took out. The clutches worked much better.
