Lesser Known Classics Discussion Forum
Schramm Compressor
Ed in Co.
12-30-2005 12:56:43
I have a 1955 Schramm 125 compressor and am looking to find what engine was used in it. It has Model "GOH" on the metal tag on the engine block. The engine block and the compressor block both look the same. Any info sure would be appreciated
Thanks
ED in Co.
jim arras
12-31-2005 07:37:51
 Re: Schramm Compressor in reply to Ed in Co., 12-30-2005 12:56:43
ED
Can you give me the serial number so I know which 125 unit you have. I won"t say I can help for sure but will try.
Jim
Ed in Co.
12-31-2005 10:46:35
 Re: Schramm Compressor in reply to jim arras, 12-31-2005 07:37:51
Also found another tag on comp. block with another number. Says, (use compressor serial 159465 and B/M no. MP-GOH-2PNS when ordering parts). The number 159465 also is on the title.
So i'm assumeing that 159465 is the mfg. ser. number of the unit,and 235635 is the ser. no. of the engine. Thanks for any info. Ed
jim arras
12-31-2005 13:02:48
 Re: Schramm Compressor in reply to Ed in Co., 12-31-2005 10:46:35
Ed, serial number 159465 was made in 1955 and is called the 125 (105) unistage compressor. I don't have a book that shows this unit in the fiftys. I have books from the thirtys and fortys. At that time they have Buda engines, from what I read gas or diesel was a Buda. I will do some more checking next week at a museum and see if they have any information on this unit. Good luck on the project
Jim
ed in Co
01-01-2006 09:09:23
 Re: Schramm Compressor in reply to jim arras, 12-31-2005 13:02:48
Thanks Jim for the info.
Ed
Ed in Co.
12-31-2005 10:18:10
Jim, the ser. no. is 235635 stamped right next to the GOH
4cyl engine and 4 cyl compressor.
The engine block looks identical to the compressor block, wi different heads of course.
