Lesser Known Classics Discussion Forum
leader oil pressure
lee thomas
11-05-2005 11:16:25
How much oil pressure should a leader ixb5 engine have ? how hard to replace oil pump ? thanks lee
J. Schwiebert
11-05-2005 13:03:07
 Re: leader oil pressure in reply to lee thomas, 11-05-2005 11:16:25
How much oil pressure do you have? What weight oil are you using? There is also a regulator you can adjust. Have you made a bearing leak detector test. I would blame the oil pump last. Questions?
lee thomas
11-05-2005 13:45:52
 Re: leader oil pressure in reply to J. Schwiebert, 11-05-2005 13:03:07
30 weight oil one gauge shows 10 lb another shows 5 lb where is the regulator located thanks
