Lesser Known Classics Discussion Forum
Huber B
Don Livingston
10-13-2005 14:41:34
Where is the serial # tag on a Huber B? Looks like it could be on the gas tank support, and it is missing. Any one have one that I could copy or purchase? This tractor is in excellent original condition.
Don L.
Brent A
10-14-2005 04:54:28
 Re: Huber B in reply to Don Livingston, 10-13-2005 14:41:34
Don if your serial number plate is missing check the plate on the right side of the engine. It should have a engine serial number on it. If you can e-mail me the number I will try to run down the correct serial number for you.
Don L.
10-14-2005 07:16:08
 Re: Huber B in reply to Brent A, 10-14-2005 04:54:28
Thanks a bunch. I will check it soon, the tractor is at a buddies place. Sounds like you have connections? Call me at 507 433 0073 or give me yours. Email is open.
Don L.
Austin Minn
Brent A
10-14-2005 08:37:22
 Re: Huber B in reply to Don L., 10-14-2005 07:16:08
Don if you are home tonight I will give you a call.
oliver fan
10-13-2005 20:17:51
The serial number plate is rivited to the main outside frame, left side below engine. It is real easy to see. If yours doesn't have one, look on that spot and see if there are 2 holes about 8" apart. That is where is was.
Hope this helps.
Don L
10-14-2005 07:17:15
 Re: Huber B in reply to oliver fan, 10-13-2005 20:17:51
Thanks Oliver fan. Do you have a B also?
Don L.
oliver fan
10-14-2005 09:15:45
 Re: Huber B in reply to Don L, 10-14-2005 07:17:15
Don, I had a B in the late '80s.
I didn't really like the tractor, so I sold it. It ended up in western ILL.
