Lesser Known Classics Discussion Forum
Looking for a Carb
Dharley130
08-13-2005 10:07:49
I am looking for a Tillotson Model YC6A carb to fit a 1948 BF Avery Model V. I've contacted all of the Avery parts guys I can find and no one has one. If you don't have one, then please keep an eye out for one at any of the shows you attend.
Dharley
08-22-2005 22:36:32
 Re: Looking for a Carb in reply to Dharley130, 08-13-2005 10:07:49
Found a new on up in Brooklyn, should arrive this week. Thanks for your help.
kingmondo
08-15-2005 18:58:05
Finally found a number on the carb. F1B
kingmondo
08-14-2005 15:28:24
I have a tillotson carburetor. Haven`t looked very hard for model number. Where is it?
Dharley130
08-14-2005 15:33:52
 Re: Looking for a Carb in reply to kingmondo, 08-14-2005 15:28:24
The number should be stamped on the pot metal bowl. It would be on the back side when the carb is mounted.
kingmondo
08-14-2005 17:33:47
 Re: Looking for a Carb in reply to Dharley130, 08-14-2005 15:33:52
Will use some carb cleaner and the aircompressor to see if I can find something tomorrow. Is the aircleaner to the left or the right of it? Sure is different from what I am used to looking at.
dharley130
08-15-2005 10:57:29
 Re: Looking for a Carb in reply to kingmondo, 08-14-2005 17:33:47
When mounted the air cleaner is to the rear of the carb. Can you take a pic of the one you have?
J. Schwiebert
08-15-2005 18:50:09
 Re: Looking for a Carb in reply to dharley130, 08-15-2005 10:57:29
I know they are tough, but who have you talked to parts source wise and do you have one to start with?
Dharley130
08-15-2005 22:42:14
 Re: Looking for a Carb in reply to J. Schwiebert, 08-15-2005 18:50:09
I've talked to several different suppliers, what is the one you are refering too? Yes I have the original carb and the parts I actually need are the pot metal bowl and the float. With those two items I could rebuilt the one I have. The bowl on mine has been hammered on through the years and now won't make a tight seal and lets unmetered air in around the gasket.
kingmondo
08-15-2005 16:47:07
How big a hurry are you in? My sister deals with selling stuff over the internet but I don`t. I would have to send photos the old fashioned way. One person i talked to said those carbs were used on model a`s.
Dharley130
08-15-2005 22:39:25
 Re: Looking for a Carb in reply to kingmondo, 08-15-2005 16:47:07
The YC6A is used on the model V, the model A"s also used a Tillotson carb but I don"t know what model
Dharley130
08-15-2005 22:44:07
 Re: Looking for a Carb in reply to Dharley130, 08-15-2005 22:39:25
If you could find the model number on the one you have it would let me know if it would fit or not. Thanks
