Lesser Known Classics Discussion Forum
What is the horsepower of my long 460
Bucyrus
07-08-2005 17:23:35
Can anyone tell me the horsepower of my long 460 and how i might find the year of manufacture of it
Thanks for any help
Milkweed
07-10-2005 03:21:11
 Re: What is the horsepower of my long 460 in reply to Bucyrus, 07-08-2005 17:23:35
Tractor Details for LONG 460 .
Tractor Details On File
Years Made: 1977-1991 Horsepower - PTO: 41.9 Horsepower - Engine: Horsepower - Drawbar: 37.5 Horsepower - Range: 42 Engine - Make: UTB Engine - Fuel: DIESEL Engine - Cyl(s) - CID: /142.8 Transmission - Standard: SG Optional: Forward / Reverse Standard: 8/2 Forward / Reverse Optional: MFWD - Standard / Optional: OPT Tires Standard - Front: Tires Standard - Rear: Wheelbase - Inches: 77 PTO Type: IND 3pt Hitch Cat I: True 3pt Hitch Cat II: True 3pt Hitch Cat III: False Hitch Lift: 2650 Hydraulics - Type: OPEN Hydraulics - Cap: 18 Hydraulics - Flow: 5.75 Hydraulics - Standard Outlets: 1 Cooling Capacity: 13.9 Fuel Tank Capacity: 14.3 Cab Standard: OPT Weight: 4013 New Price: $9,608.00
Marv
07-08-2005 20:42:52
You MIGHT find the year cast into he top of the head or the trans case or a rear axel housing. The serial number bears no relationship to anything.
Jim in NC
07-08-2005 17:45:05
I have a 445 that is rated at 42 hp. The 460 is the newer version of the 445. I think the hp is the same. There should be a plate on the side of the transmissiom case that will give you the model and serial number. I forget which side. You could go to farmtrac.com and contact a dealer. He may be able to tell you the year of manufacture.
