Lesser Known Classics Discussion Forum
Long 560 Hyd problems
Joe Bard
05-24-2005 16:41:04
Hello,
I am looking at buying a Long 560 from a local dealer. They are selling it 'as is' for $3800. They told me it needs a hyd pump. 3pt and steering wont work. They say you have to split the case to get at the pump. It has a loader on it. Pretty good shape otherwise. 3600hrs showing.
Is the pump expensive to rebuild/replace? Any thoughts comments? Anybody know the specs of the tractor? They thought it was 55hp.
jason oh
05-25-2005 18:45:55
 Re: Long 560 Hyd problems in reply to Joe Bard, 05-24-2005 16:41:04
the tractor has two pumps on them one for the hyd and one for the power steering if both are not working it could be a dirty filter,if the draw the oil for the same resivor some had a sepreate tank for the power steering the chances of both pumps being bad is rare in either case you don"t need to spilt the tractor to change the pump
Joe Bard
05-26-2005 03:21:21
 Re: Long 560 Hyd problems in reply to jason oh, 05-25-2005 18:45:55
Ok that sound true. None of the pumps are noisey at all. It looks like the front pump that drives the power steering is actually two pumps?? I am going to get a manual and test the system if i can. ANy other input would be great!!!!! Thanks!
Jim in NC
05-27-2005 03:43:56
 Re: Long 560 Hyd problems in reply to Joe Bard, 05-26-2005 03:21:21
The front pump is for the hydraulic lift and the rear pump is for the power steering. There are several troubleshooting steps-the first and main one is to clean or replace, if really dirty, the hydraulic oil filter and change the hydraulic oil. If the filter is full of gunk and the oil is gray or milky, this may be the most likely cause of the problem.
Joe Bard
05-27-2005 06:02:27
 Re: Long 560 Hyd problems in reply to Jim in NC, 05-27-2005 03:43:56
Jim thanks for the info. I did buy the tractor - it should be home today.
There are two pumps on the timing cover housing. It looks like one feeds the other - maybe a hi volume/lowpressure into a high pressure?? These appear to goto the power steering.
I was told there is another pump under the seat in the housing. Was told this pump feeds the 3pt hitch and loader.
Someone added a seperate pto pump to run the loader. I want to get rid of that so I can add a mower.
Any help would be great!!!!! !!!!! !
Jim in NC
05-27-2005 09:02:46
 Re: Long 560 Hyd problems in reply to Joe Bard, 05-27-2005 06:02:27
Joe, I have never seen one as you describe. The ones I have seen have 2 pumps under the injection pump. The front one operates the hyd. lift, oil intake from the bottom and pressure line out the top to the lift under seat. The pump facing the rear is the power steering pump. Its oil supply comes from the same line as the hyd. pump and pressure line goes to ps cylinder. AS far as I know, the pumps work indepently from each other. I have a 360 and a 445 and my brother has had a 445 and a 610. I was at a local long dealer yesterday and looked at one as I have described to you. I hope this doesn't confuse you too much. Good luck with your tractor.
Jim in NC
05-28-2005 19:08:01
 Re: Long 560 Hyd problems in reply to Jim in NC, 05-27-2005 09:02:46
Joe, the filter housing is in the Hydraulic oil supply line that runs from under the transmission-rear end area to both pumps. The filter goes in this line below the starter. You will see a cover with 2 bolts here. There is a magnet to catch shavings and an o ring to seal it. You need to install a filter if there is not one in the system. It is a wire- mesh cylinder and can be cleaned with diesel or gas and compressed air after drying. My dad used to think the lift worked better if it was removed, but you need it to protect o rings and seals in the lift and pumps. If the hydraulic pump and lift are working properly, the resistance created by the filter will not hinder performance. There are a couple of tricks that I have found that have helped me when having hydraulic trouble with longs. I can try to explain them here but the posts would be rather long. You can email me or if you want, or I can send you a phone number. Long hydraulics are a weak part of the tractor, but overall my problems have been minor ones. Good Luck and remember our troops!
Tim McLain
12-04-2005 10:03:23
 Re: Long 560 Hyd problems in reply to Jim in NC, 05-28-2005 19:08:01
My Long 560 has no hydralic assist until you put the front end 1-2 foot lower than the back wheels for a short while. Once primed the system seems to work ok. I have not tried to lift anything with the 3-point yet though. Could the filter cause this condition?
Larry G. Allen
06-06-2005 10:54:02
To Jim in NC. I have a LONG 2510DTC and have had two problems #1 transmission locks up a lot of times in 4th gear does not do it in any other gear. #2 My hydraulics, I have put O-rings in so many times I couldn"t count. [under the seat] sometimes it takes 10 mins to pick up woods mower I also have dual hydraulics. I love the tractor but wish I had bought shuttle shift Any info appreciated I can"t find a manual for tractor, the one that came with [poor printing smudged] THANKS [bought new wih loader 4wd
Joe Bard
05-28-2005 14:58:51
Jim you are correct. Tractor is home. Changed the fluid. Could not find a filter. Is there suposed to be one in the feed line? There is a block off plate which I removed, but no filter. Both pumps are pumping, but does not seem to be much. Cracked the lines to test that. Getting a gauge to put on them next. Wish me luck!
Georgie
07-19-2005 18:09:52
 Manual in reply to Joe Bard, 05-28-2005 14:58:51
I just bought a Long and I was wondering where I could get a manual at,Thanks
