Lesser Known Classics Discussion Forum
Silver King Model 42 front fork assembly
Jason with Silv
04-12-2005 18:44:30
Hello,
I have disassembled my front fork and most of the bearings are in pieces. I have barely enough lower bearing to find a replacement and if there is an upper bearing, it came out in small chunks. Anyone got a bearing number or a picture of how this all goes together? Are their spacers between the upper and lower bearing? Any descriptions and help is appreciated. If nothing else, I will take some measurements and find bearings that will work.
Larry from MD
04-13-2005 09:25:50
 Re: Silver King Model 42 front fork assembly in reply to Jason with Silver King in, 04-12-2005 18:44:30
The older parts book i have shows pictures of parts,but not an exploded view of how they go together.most of the bearings have Silverking part numbers not the bearing number.I do have an upper fork bearing number of torrington B-2420.You should measure your shaft and see if the bearing place says its a match.
