Lesser Known Classics Discussion Forum
Long 2460
Gary Mckenzie
03-31-2005 14:42:37
Anyone know where I can find a good used engine or block for a Long 2460? The piece that the water pump attaches to is busted, and there's water in the oil. The owner forgot to put antifreeze in it. Thanks!
marv
03-31-2005 18:57:08
 Re: Long 2460 in reply to Gary Mckenzie, 03-31-2005 14:42:37
More info please. A cast iron adapter bolts to the block. The water pump bolts to the adapter. The adapter is available seperately. Are you sure the block is busted? Remove the rocker cover and check the top of the head. It has "freeze" plugs which may be blown out. If/when you need parts email me.
Gary Mckenzie
04-01-2005 11:33:32
 Re: Long 2460 in reply to marv, 03-31-2005 18:57:08
I know about the adapter, but will check the freeze plugs. Can you get the adapter? My email is open. Thanks!
