Lesser Known Classics Discussion Forum
Long 1100 Water pump
Green 88
02-28-2005 07:06:48
Looking for a water pump for a Long 1100. It has a diesel motor. Would like to buy a new or rebuilt.
Thanks
Dsl
03-05-2005 15:59:00
 Re: Long 1100 Water pump in reply to Green 88, 02-28-2005 07:06:48
Click on my name to send me an email; I should be able to help you.
BG in NC
03-05-2005 13:34:16
Hope this helps. Long made a 1100 in the early - mid 70"s .It was the same tractor as the 900 except it had a turbo. Then it was changed to a 1110 . The tractor had a zetor engine in it . The engine was 285 cu. in. with a bore of 4.33 in. and a stroke of 4.72 in. and a compr. ratio of 17:1 . I had a 900 and a 1310 years ago and they were good tractors. The engine was the same in a zetor crystal 8011? (I think those #"s are right). You can look on zetor "s website for possible parts or a dealer near you or you can try Long equipment co. in Tarboro, N.C. at (252) 823-1163 or 1-800-488-2012.They may still have some parts or at least, tell you who might. To confirm we are talking about the same style tractor , go to toyfarmer.com and look for past issues of their magazine and look for April 2003 cover. I built a toy model of a 900 and it is the same as a 1100. We purchased our first Long in 1974 and have a lot of experience with them . Have you ever had problems with the brakes overheating? I can tell you how to fix them . Good luck . BG
Bus Driver
02-28-2005 16:11:15
I could find no info on that tractor, but it must be a rather large one based on the model number. Long has offered large tractors with 6 cylinder Perkins engines. Perkins probably has CAV injection system, if that will help identify it. Some of the other larger Longs used Zetor engines. Hope my guesses help.
