Lesser Known Classics Discussion Forum
Nuffield 460 Exhaust Oil
David Kierans I
02-15-2005 05:43:39
I have a restored 1960 Nuffield 460 which has started throwing out spots of black oil from the exhaust in addition to dribbling some from the exhaust manifold gasket. This seems to occur when the engine is cold or left ticking over for a while. Could it be worn valve guides letting oil down from the rocker shaft? Is there valve seals on these engines?
Any advice would be appreciated.
Dave Sherburne, NY
02-16-2005 17:19:43
 Re: Nuffield 460 Exhaust Oil in reply to David Kierans Irl, 02-15-2005 05:43:39
Its probrobly unburned diesel fuel. Does it do it when the engine is warmed up?? Hot?? If you don't run it enough to get it hot when
you use it , try putting something in front of the radiator, watch your temp gage.
