Lesser Known Classics Discussion Forum
LeRoi 4 cyl engine.
Nelson Saxe
02-11-2005 17:24:49
I need a carb for the above engine. It's the type that has the cone shaped govenor controlled by a clock type coil spring. Spring and butterfly housing on mine is damaged beyond repair. Also let me know if you know of a subsitute.
Engine is powering a Gifford Wood Ice Saw when it runs.
Thanks in advance.
Nels
wrong name agean
03-27-2005 22:16:45
 Re: LeRoi 4 cyl engine. in reply to Nelson Saxe, 02-11-2005 17:24:49
I have complet engine 4 cyl flat head it came off a leroi cement mixer,somebody left the stack cover off so now it is stuck,i think it would be a easy fix ,the radiator is not right i live in oregon. pat
george md
02-11-2005 20:52:20
Nelson, I have a home movie of the last filling of an
ice house in north jersey . The ice saw used to
cut the floats and score it for cubes had a leroy engine on it , but I don't know what brand
the saw was. The last filling of the ice house was in 46 or 47 . If your housing is a casting , send me a picture
of the damage and there is a good possibility that
I can repair it. I do oxy/acetylene cast iron
welding not arc welding. Link below will get you
to my web site and in it there is a link to some
cast iron repair and also my email addy.
george
