Lesser Known Classics Discussion Forum
Long tractors
j.w.intex
02-06-2005 05:49:29
Im thinking about buying a 1981 long 510, its in good working shape,what I need to know is are they any good and whats a fair price?
Phil B.
02-09-2005 13:01:39
 Re: Long tractors in reply to j.w.intex, 02-06-2005 05:49:29
I have an "82 510, and it has been a very stout tractor. It has a front end loader, and about the only thing I can complain about is that the Hydraulic pump doesn"t flow enough and the loader is slow. ( Does anybody know if there is a larger pump available?) Other than that, it starts every time I need it, and sometimes it will go months without use, and start right up. Yup, it"ll leak a little. I put cardboard under mine. It"s not too bad.
geok
02-10-2005 19:44:35
 Re: Long tractors in reply to Phil B., 02-09-2005 13:01:39
Yes there are larger gpm pumps available from you Long dealer. I would have to check and see if they are available form aftermarkets sources.
Robert jernigan
02-08-2005 11:59:11
I have owned a Long 560 for about 15 years the only trouble I have A Loder on it and have had to replace the hydrolac pump so if you like go for it they are good Tractors I am looking for a 6 or7 foot rotiteler if anyone knows of one send me Email at [email protected]
Jeb2N
02-06-2005 14:48:19
The old longs like the one you mention were pretty dependable but were prone to some bad leakage problems. If you don't mind the leaks, they tough tractors.
Kenneth W. Boland
02-15-2005 13:22:50
 Re: Long tractors in reply to Jeb2N, 02-06-2005 14:48:19
Should the fluid level in the transmission be checked hot/cold, running/off?
