Lesser Known Classics Discussion Forum
leyland 384 and 270 question
speedbuff
02-06-2005 05:42:47
hey all you leyland guru"s i just purchased a 270 tractor and i have a 384 manual is this tractor the same ? I know that the 384 was its predecessor but what if anything was changed ? also does anyone have a leyland VIN breakdown and what the #$%%^! does 4/98 stand for? THANKS IN ADVANCE speedbuff
shorty007
09-02-2006 22:36:23
 Re: leyland 384 and 270 question in reply to speedbuff, 02-06-2005 05:42:47
Hey speedbuff just wondering where did you obtain your 384 manual?I have been looking for one for ages
speedbuff
03-04-2007 12:21:14
 Re: leyland 384 and 270 question in reply to shorty007, 09-02-2006 22:36:23
do you still need a manual if so i have some email me if you do
john mc crank
02-21-2005 13:21:47
tractors are the same 384 just earlier model prior
to change to 2 series numbers.
marlowe
02-16-2005 19:32:22
270 has more head bolts as the 384 liked to blow head gaskets
speedbuff
02-17-2005 02:58:39
 Re: leyland 384 and 270 question in reply to marlowe, 02-16-2005 19:32:22
Thanks for your reply marlowe i was hoping you knew how to break down the vin also ? anyone?
marty g.
02-08-2005 04:41:41
Try this site, there is a lot of knowledge for that kind of tractor over there.
Link
But I have one question for you, I have a 384 and am wondering about the location of the PTO on your 270, mine sits pretty high above the draught bar. I'm pretty sure 4/98 is an engine model number.
speedbuff
02-08-2005 16:24:40
 Re: leyland 384 and 270 question in reply to marty g., 02-08-2005 04:41:41
The location is the same on both tractors the tractors are very close I am just curious what the small differences are ? Someone here will know Please reply Also i just wondered what the 4 98 stood for likely 4cyl but i am lost on the rest
marty g.
02-09-2005 05:02:25
 Re: leyland 384 and 270 question in reply to speedbuff, 02-08-2005 16:24:40
98 MM bores...
more info at this other forum:
http://leyland.conforums.com/index.cgi?board=general&action=display&num=1040040948
speedbuff
02-09-2005 15:48:58
 Re: leyland 384 and 270 question in reply to marty g., 02-09-2005 05:02:25
thanks marty i knew there had to be a perfectly good reason for the 98 how about the diffs between the two tractors?anyone?
Fighting suburbia in NC
02-10-2005 12:58:55
 Re: leyland 384 and 270 question in reply to speedbuff, 02-09-2005 15:48:58
Only dfference is the year manufactured, as far as I know. 384s were produced in early 70s followed by 270 in early-mid 70s. Mechanically identical as far as I remember - the farm I grew up working on had one of each and they were identical in all respects that I know about.
Monty Pitts at Anglo-American can tell you for sure. The 384 manual should cover everything you need for routine maintenance.
speedbuff
02-10-2005 15:00:06
 Re: leyland 384 and 270 question in reply to Fighting suburbia in NC, 02-10-2005 12:58:55
Thanks suburbia fighter i think all the info you could cever want is available here from all you guys How about the serial no 270n 303238/z 177129 does anyone know how to break this down ?Can this tell you what year it was produced? thanks in advance
