Lesser Known Classics Discussion Forum
Silver King Connecting Rod
Jason(PA)
12-29-2004 18:37:01
Im rebuilding a Model 42 Silver King with the F 162 Continental engine. My question is about the bushing in the top of the connecting rod. Should it move around the inside of the rod or should it be pressed in and stay still? Mine slides around and I wonder if it is that worn out or is it like that. Any other engine I've done it is pressed in. Thanks for any help!
Jason
J. Schwiebert
12-31-2004 00:57:34
 Re: Silver King Connecting Rod in reply to Jason(PA), 12-29-2004 18:37:01
They are pressed in and then honed or bored to size. Clearance is less than 0.001. Also Not all F model Continentals use the same bushings. Have all four reconditioned while you are at it. The bottom (big) ends tend to go egg shapped.
Jason(PA)
12-31-2004 08:41:34
 Re: Silver King Connecting Rod in reply to J. Schwiebert, 12-31-2004 00:57:34
Thanks for your help! I found a machine shop that has alot of parts they can get for this engine and they do pretty good ork so I think I'll be ok.
Galen Ishman
12-30-2004 05:11:09
I beleive they are pressed in. I have some spares down in the barn that I will check to make sure.
