Lesser Known Classics Discussion Forum
Rumely Model M Specs
Frank from MacN
12-28-2004 14:56:43
Need to know the Clearances and torques etc. for a Rumely Model M Oil pull tractor engine. Any help appreciated Frank
test
05-28-2005 10:32:56
 Re: Rumely Model M Specs in reply to Frank from MacNutt, 12-28-2004 14:56:43
n/t
Craig Anderson
12-31-2004 18:40:30
There really aren't any specs..... only common sense. Just the normal stuff for rocker arm clearances. Bolts and such? TIGHT..... but not CRAZY tight. I don't know how big a guy you are, but for the head bolts I (6' 150lbs.) tightened all I could using a 3/4" drive ratchet about 2' long, without a cheater, and never had any problems. I DID use a cheater on the conn rods though when it was necessary to get to the next castellation in the nut. NEVER back off a conn rod nut to get the cotter pin to fit....unless it's only half a slot or so. I had a 1926 M.....what year is yours? Craig
