Lesser Known Classics Discussion Forum
The General Tractor
Jim Stodolka Sr
11-30-2004 19:09:39
hi, does anyone have any information on the General tractor. i have a chance to buy one for 500.00, the motor is loose and the tractor is complete, it has a single front wheel. anyone know if the price is right and is it worth the effort to go and get it? thank you, jim
jim stodolka
12-14-2004 12:50:37
 Re: The General Tractor Parts needed in reply to Jim Stodolka Sr., 11-30-2004 19:09:39
just hauled my general tractor home today, does anyone have rear rims, drive shaft cover and grill? not sure what else i will need yet. has been setting for 20+ years in a woods.
Gene Davis (GA)
12-16-2004 20:29:56
 Re: The General Tractor Parts needed in reply to jim stodolka, 12-14-2004 12:50:37
Some of the stuff will interchange with the B.F. Avery "A" series tractor. Might look for stuff that way. Mike Ballash, AKA "Alberta Mike" has a lot of information on these critters, post him a note for more information. He has compiled a short history lesson on them also. Gene Davis
Jason(PA)
12-03-2004 16:06:33
 Re: The General Tractor in reply to Jim Stodolka Sr., 11-30-2004 19:09:39
I would give $500 for it!!
Jason with Silver King in
11-30-2004 20:09:38
There is an article on this website somewhere about the Cletrac General (Cleveland tractor company). After Cletrac quit making them, they were manufactured by B.F. Avery as their "Model A." If I knew of one that was complete and loose for $500, I would buy it. I think they are just neat and the General's are pretty rare, but the Model A's show up on Ebay quite often. Be wary, I have seen two General's on ebay over the last couple years that were actually Model A's with General paint and decals. The serial number is what you need to verify. I also think that Cletrac used a different and/or smaller Hercules engine than B. F. Avery. Just my two cents.
craig in michigan
01-03-2005 07:29:55
 Re: The General Tractor in reply to Jason with Silver King in, 11-30-2004 20:09:38
Mine has a IXk3 engine in it
J. Schwiebert
12-01-2004 11:37:20
The General has a metal serial number tag which has Cleveland Tractor Company on it. The Avery has the serial number stamped with a number set. The first Avery model A tractors are identical to the General. Then things changed. Remember this was World War two and things were tough to come by. The first Generals had the IXA and then the IXK Hercules engine same as the Avery. The General was built from 1939 untill sometime in 1941. Serial number tend to follow Cletrac practice but they have the early set up for the first tractors and the later set up for the last ones. Where are you located?
