Lesser Known Classics Discussion Forum
WICO Magneto
Dean
11-27-2004 07:10:25
I have a new looking WICO Model X, No. Y-54, Spec. XH-1343 magneto in a Fairbanks-Morse box labeled FM-ZV4B7, Wisconsin Motor Corp., VE4 and VF4. The magneto is for a 4 cylinder application. Clearly the box is incorrect but, perhaps, someone swapped a FM for a WICO on a Wisconsin engine years ago. Does anyone know if this magneto fits a Wisconsin V4 or, if not, what it does fit? Also would like to know what it is worth. Mag is complete with impulse coupling and works fine.
Dean
Larry from MD
11-27-2004 15:41:29
 Re: WICO Magneto in reply to Dean, 11-27-2004 07:10:25
The wico X or XH is one of the most adaptable mags ever.They are very common as replacements and OC.If it has a gear drive it probably fits a wisconsen.If it has a lug drive and the flange mount it would fit lots of other stuff.They allso came with base mounts to replace older mags.
Dean
11-27-2004 16:07:31
 Re: WICO Magneto in reply to Larry from MD, 11-27-2004 15:41:29
Thanks for the info. Mag in question has flange mount and lug drive. The flange looks much like that I have seen on AC WCs and some WDs. But most ACs that I have seen have had FM mags.
Dean
Larry from MD
11-28-2004 08:47:39
 Re: WICO Magneto in reply to Dean, 11-27-2004 16:07:31
Yes the FM mag would be oridunal,but the wico is replacement mag for that engine.Tune up parts are available from many differant places,and they are easy to work on.
