Lesser Known Classics Discussion Forum
PASQUALI/LOMBARDINI SHUT OFF
KUMAN
11-07-2004 17:09:55
CAN ANYONE PLEASE EXPLAIN WHY I SHOULD SHUT OFF MY DIESEL TRACTOR WITH A KNOB RADER THEN IGNITION KEY. DETALES GREATLY APPRITIATED.
Vinny95
11-10-2004 19:01:30
 Re: PASQUALI/LOMBARDINI SHUT OFF in reply to KUMAN, 11-07-2004 17:09:55
I have a Ferrari that operates the same way. The knob is your fuel shutdown on the injection pump,which is the proper way of shutting it off. If you shut it off with the key(which it probably WON'T) excess fuel will be pumped into the cylinders at shutdown,possibly getting by the rings and into the crankcase,which is a bad thing. Do you have any info as to where I can find an engine manual,by the way? Thanks.....
AMERICAN PASQUALI
07-18-2006 05:53:27
 Re: PASQUALI/LOMBARDINI SHUT OFF in reply to Vinny95, 11-10-2004 19:01:30
we are AMERICAN PASQUALI located in New Hampshire you should never turn the key of while the engine is running on any pasquali as it can damage the voltage regulator. We sell new and used PASQUALI parts (603)526-9493 THANKS Jack
gardener
02-12-2005 16:12:10
Try this..... ... www.ferrari-tractors.com/
