Lesser Known Classics Discussion Forum
skidsteer loaders
wm
10-24-2004 09:37:20
Do these loaders have a problem with driveline windup on hard surfaces? I'm familar with windup with some 4 wheel drives on pavement and am wondering if hard surfaces conbined with different tire diameters(due to wear) wouldn't put huge stresses on the drive chains and sprockets of these loaders. I have an operators manual but theres nothing in it about this. thanks for any help,wm
learningtractors
01-08-2005 15:24:45
 Re: skidsteer loaders in reply to wm, 10-24-2004 09:37:20
I WORKRD ON BOTH BOBCAT AND CASE SKID STEER
AND BLACKTOP AND FLAT CONCRETE DOES PUT ALOT
OF UNDO STRESS ON THE DRIVE CHAINS ON BLACKTOP OR
ANY HARD SURFACE ITS BEST TO MAKE YOUR TURNS AS WIDE OR LONG IF YOU WILL AS POSSIBLE INSTEAD OF SPINNING AROUND ON A DIME AND YOU WILL HAVE LONGER WEAR ON YOR CHAINS
fast19
11-02-2004 07:36:15
Remember they are designed to skid the wheels! The only problem is tire wear and tear.
