Lesser Known Classics Discussion Forum
Surging Silver King
Jason(PA)
10-11-2004 16:44:58
Im been working on my new "Toy" and finially got it running. Runs pretty good for sitting the last 12 years. Anyway the engine is surging at idle. I assume its the governor. What actually inside there is causing this? And where on earth am I going to find parts for it? Its a model 42 with the Continental engine. I know that the Massy Harris 30 uses the same engine,but the Gov is on the front part of the engine and I don't know if its the same. Any help would be greatly appreciated! Thank You!!
Bob
10-12-2004 08:05:31
 Re: Surging Silver King in reply to Jason(PA), 10-11-2004 16:44:58
Often, surging is caused by carburetor problems.
If the idle and power circuit in the carburetor are not both set properly and functioning properly, the carburetor will not respond to a small movement of the governor, and a bigger correction will be made by the governor, causing surging.
Also, the length of the linkage rod from the governor to the carburetor is important. In general, the carburetor throttle shaft should reach the end of it's rotation in the "open" direction just before the governor reaches the limit of it's movement in that direction. Hopefully, you have the original linkage and carburetor, so the geometry of the levers and linkage is as it was originally.
Is the governor belt drive? If so, be sure the belt is in good condition, and reasonably tight. If the governor is external, be sure it is properly full of oil.
If all else fails, and you have to tear into the governor, check for the weight pivots either being tight (sticky), or loose and sloppy. Check the thrust bearing, and the fingers on the weights that touch the thrust bearing, and the forked lever that touches the other side of the thrust bearing for wear (flat spots) that affect the smooth movement of the governor parts.
Check the bearings, and the bushings on the input/output shaft(s).
Jason(PA)
10-12-2004 17:43:56
 Re: Surging Silver King in reply to Bob, 10-12-2004 08:05:31
Thanks for the help. I think I have narrowed it down to the carb being the problem. Thanks agian!
