Lesser Known Classics Discussion Forum
Schramm timing mark
Scott Hetzner
10-10-2004 16:09:47
Can anyone tell me where the timing mark is on a Schramm model 75 air compressor? I need to know where it is and what degree it is?
samuel storti
02-28-2005 17:08:16
 Re: Schramm timing mark in reply to Scott Hetzner, 10-10-2004 16:09:47
the timing marks are located on the two gears ,if you just want to set magneto ,crank engine with spark plug removed from #1 cylinder with thumb covering hole until compression pushes your thumb away ,that will put it at top dead center. get the magneto and set the rotor at one o"clock. if you can"t get the first few tries, keep at it, you will get the idea
