Lesser Known Classics Discussion Forum
Schramm Fuel pump
George S. in th
09-16-2004 06:04:44
I have a approx "72 Schramm Pneumatractor and need to add a mechanical fuel pump. This tractor is a diesel and the injector pump needs some help to get fuel thru the filter set up that I now have on it. I know, I could use electric but now this tractor is a mix of 12 and 24 volts with no charging hooked up. So, mechanical pump means I can tow start it and not worry about volts and amps. Can anyone tell me a model and make of fuel pump that will work?? I think the gas powered models that had the fuel tank under the operator"s platform would have had to have a fuel pump. My tractor has the hole for fuel pump and the cam has a lobe. The only parts book I have is for a 57 model which had the tank at the back of the hood and uses gravity feed to the carb. Thanks.
