Lesser Known Classics Discussion Forum
Model 610 ??????
streaker
08-31-2004 14:37:36
I am trying to find sleeves for a Long Model 610, that is the model number on the hood of the tractor, BUT on the serial # tag it says..... .....MODEL # 1582 Ser# 660172..... .(tag near footrests), and the dimensions of the new sleeved dont match up to the dimensions of the old pistons HELP !!!!! Thank you in advance.
Jason (OH)
08-31-2004 17:31:25
 Re: Model 610 ?????? in reply to streaker, 08-31-2004 14:37:36
"dimensions of the new sleeved dont match up to the dimensions of the old pistons "
What is the problem? The Id of the sleeves to small? I am not sure if the 610 used to different sizes or not some used a 95mm and others used a 105mm they are identified by the letter A stamped on the piston for the 95mm and B for the 105mm at any rated the sleeves need to be installed then bored to size.
streaker
08-31-2004 17:44:26
 Re: Model 610 ?????? in reply to Jason (OH), 08-31-2004 17:31:25
Well i"ll start here...The O.D. of the piston is 3.985 and the I.D. of the new sleeves are 3.812....I sholdn"t have to bore out .170+ thousandths should I? This is the dimension that the distributor gave me for the new ones. Could this be some sort of Fiat engine? The codes on the block are as follows: D121.050 Ser#004503, Code#121058 That is all I have to go on. Thank You!
Marty g.
09-02-2004 04:53:33
 Re: Model 610 ?????? in reply to streaker, 08-31-2004 17:44:26
If it is UTB, sold as a Long, it's manufactured in Romania. It was a technology transfer from Fiat. They are using Fiat molds for most of the parts, but it's not Fiat. Most Fiat sleeves come unfinished, so I suspect the same for your Long engine.
marv
08-31-2004 19:49:23
All Long/UTB sleeves must be bored and honed to fit the pistons.
