Lesser Known Classics Discussion Forum
long 445 power steering
Jason
08-05-2004 19:02:02
Long 445! What would make the steering wheel want to turn to the right, all by itself. ?air or bad cylinder?? There is one cylinder on the left side of the tractor attatched to the left steering arm. Any Help?? Thanks
joe WNC
10-24-2004 07:11:30
 Re: long 445 power steering in reply to Jason, 08-05-2004 19:02:02
I have a 510 4WD that had a similar problem. To make it not turn you had to constantly turn the wheel the other way. I rebuilt the steering piston and fixed the problem. The difference was so great that I felt bad for not noticing the slow loss of control before then. It was only ten bucks for the parts to fix it.
geok
08-09-2004 20:36:26
Your tractor is equipped with what is called power assist steering. It can be adjusted by loosening the clamp bolt just behind where the steering link is connected to it. Hold the valve body with you left hand and try to turn the chrome rod with yor right. Turn it a 1/4 turn in one direction and then see if it improves. If not turn it back the other direction a 1/4 and check the results.
