Lesser Known Classics Discussion Forum
Long 445 Diesel Hydraulics
Jason
08-02-2004 15:17:39
I mowed with this 445 for 20 min. (It sat for 3 years before i bought it) shut it down started it back up and the hydraulics would not work! the oil looked like milk so I drained it , filled up with new and still no hyd.I checked the Magnetic filter it looked clean. I loosened one of the lines and no fluid came out?? Any ideas on what to look for. 1978 445 3cyl.Diesel 1600 hours with a Front loader does anyone know its value? Thanks In Advance
Edde
08-09-2004 13:45:07
 Re: Long 445 Diesel Hydraulics in reply to Jason, 08-02-2004 15:17:39
I have a 445 4x4 that does the same thing every now and then. Be patient, it always comes back. I find that it takes very little contaminated fluid to lose hyd pressure, and/or perhaps it's the valve sticking but it should self bleed any air out on it's own. I paid $2K for mine ten years ago and wouldn't sell it for a penny less. I have a shop manual if you need anything scanned, etc. Enjoy!
Bus Driver
08-03-2004 04:31:50
Geo has posted here about a valve that sticks and causes this condition. The valve is under a big nut under the seat of the tractor. Says there is a spring there also. Clean it all and reassemble as original. I have not done this personally. You do know the hydraulic oil is shared with the transmission and it holds maybe 6 gallons. There may be dipstick near the gearshift lever for checking the level.
Jason
08-03-2004 20:14:00
 Re: Long 445 Diesel Hydraulics in reply to Bus Driver, 08-03-2004 04:31:50
Thanks Bus Driver I do remember seeing something like that under the seat but i didn't want to be wrenching on something not knowing! I will check that out next...
Jason (OH)
08-02-2004 18:23:21
You may have lost prime in the pump when you drained the oil. What I do it take the pressure line off the pump and put a little oil in it then crank the motor over until it pumps then reinstall the line
Jason(IN)
08-03-2004 20:22:56
 Re: Long 445 Diesel Hydraulics in reply to Jason (OH), 08-02-2004 18:23:21
thanks J I had lost all hyd. before I drained the hyd. oil. I did take the line off and put oil in the pump. also today i took the pumps off to check the cog that is driven by the timing gear. It all looked good, but what do i know! I will try bus drivers idea tommorrow. Thanks
