Lesser Known Classics Discussion Forum
satoh 650-G one-way clutch noise
john fittler
07-18-2004 17:01:09
Is it normal to hear a knocking noise by the high/low lever in the transmission when you run a chopper on a 650-G tractor and then depress the clutch stopping the live pto ? When I depress the clutch, the chopper eventually comes to a stop but you hear a knocking noise in the gear shift housing. I was told this was normal because the tractor has a one-way clutch which prevents the tractor from surging forward when the clutch is depressed until the chopper stops as an old ford tractor would do like an 8N. How much noise is considered normal ?
