Lesser Known Classics Discussion Forum
Power steering question
Randy
07-15-2004 16:48:31
Hi all,
I was wondering about the need for a hydraulic pump to power the power steering of my Long 445 tractor. It is expensive to replace and prone to damage since it shares gear box oil. Couldn't I replace it with a belt driven power steering pump from a Ford 1/2ton truck or something similar?
Randy
geok
07-18-2004 19:31:01
 Re: Power steering question in reply to Randy, 07-15-2004 16:48:31
Pumps are available through aftermarket sources. If you don't want to use tranny oil, set up a steering oil can reservoir like the newer models.
Bob
07-16-2004 11:12:49
The Ford PS pump may be set to a lower pressure, but it sounds like it may be worth a try!
