Lesser Known Classics Discussion Forum
Mule ignition problem
Gene
07-02-2004 09:44:33
My apologies if this is too far off topic but I have received such excellent advice here in the past on tractor problems that I thought this might be my best bet at getting help. I have a baffling ignition problem on a Kawasaki Mule 1000 utility vehicle (the original Mule model introduced in 1988). The problem started with one of the cylinders missing on the 2 cylinder engine. I pulled the spark plugs, which were pretty new, and they looked fine so I cleaned them up and replaced them. I also replaced the spark plug wires as they were still the originals. When I started it up it was still missing. Next I switched the two spark plugs and tried again and the opposite cylinder was missing. That told me it was a bad plug so I replaced both plugs and it ran just fine. Problem solved... or so I thought.
About 2 weeks later it started missing again. As I was determining which cylinder was missing I made an interesting discovery. When I pulled one of the spark plug wires the plug started firing briefly. I found that if I left the wire very loose on the plug it ran fine. I left it that way to see what would happen. A few days later the other cylinder started missing. Same thing. I used it for a while with both spark plug wires very loose. Eventually it started missing again and finally wouldn't start at all. With another new set of plugs it again started right up. It wasn't long before it was missing again. I pulled both plugs, grounded them with the spark plug wires attached, and ran the starter. One fired and the other didn't. Then I pulled the plug that wasn't firing away from the ground while running the starter. When I got about 1/8 inch away it started firing, also sparking between the plug and the ground.
I changed brands of plugs to the exact NGK plug recommended in the manual. Again, after running fine for a while it started missing again. The plugs are not fouling, just a very light coat of black carbon. I have gapped the plugs to specs very carefully. Once the plugs stop firing they seem to be permanently ruined. No amount of cleaning will make them work properly again, although they will always fire at least for a while with the plug wire pulled back so that it is not quite contacting the plug.
My nearest Kawasaki dealer is as baffled as I am. I hate to haul it in for repair if it is a simple fix. The dealer says the electronic ignition module can't be tested, but the first thing he would try is replacing that. Unfortunately, he wouldn't know whether it fixed the problem until I used it for a while, and at that point I pay for it whether it helps or not. If I am going to try that I might as well replace it myself, but I hate to spend that much without being pretty sure that is the problem.
Any thoughts? Many thanks.
Mule
11-23-2005 12:12:01
 Re: Mule ignition problem in reply to Gene, 07-02-2004 09:44:33
I also have a older Mule 1000 with the same problem and was wondering if you were able to fix the problem and what it took to fix it. Thank You
Larry from MD
07-02-2004 16:38:52
Pulling the wire away intensifys the spark.It allso works the coil harder.My father would do it on one clinder in an engine to get it to start fireing,then hook it back up and run it.My guess would be a bad coil or electronic egnition.
Dee in mid MO
07-02-2004 15:10:59
sorry, couldn't resist but some of the mules I know have serious ignition problems between their long antennae ears.. <~:) Have a good 4th tho'. Dee
