Lesser Known Classics Discussion Forum
rear end/pto clutch cover. Model 445 Universel
Stan Heath
06-25-2004 10:01:27
I have removed the hydralics from under the seat and then the cover plate over the pto clutch area. Where can I get the rubber seal which seals the hydralic dextron II through the clutch/rearend cover. There is also an oil ring on a small extension port which enters the hydralic unit. What is the rubber compound used, (buna N, etc.)? I am also confused of the type of seal which was used between the (1) the cover plate and the tractor, and (2) the hydralic unit and the cover plate. There were only silicone used by the prior owner which leaked Dextron in the rearend and some 90W out from the coverplate. The dextron found its way into the rearend compartment by way of the mounting bolts for the hydralic unit. I hope this is enough info for some responses. No help in this part of the country; mostly John Deeres and Fords. Southern Oklahoma. Thanks in advance fer yalls help, Stan
