Lesser Known Classics Discussion Forum
what type of cultivator is this
joe
06-03-2004 20:20:05
i have a front or under the engine mount row cultivator with the following painted information on it. i can get the individual part numbers off of it if you need. any info a great help. thank you and God Bless
1) NO 1057 QD CENTER Pat. 2 308 667 U.S.A.
2) NO 1057 QD OUTSIDE Pat. 2 361 362 U.S.A.
joe
06-03-2004 20:24:16
 Re: what type of cultivator is this in reply to joe, 06-03-2004 20:20:05
ps i had a guy make some new wood bearings for my old disk harrow. he made them out of a very hard wood. what should i use for lub i tried boiling them in 80-90W oil, for about 10 minutes. a lot of good that did, stunk up to you know where made a mess and the bearings only look a little wet now. would whell bearing grease do the trick or just lots of oil.
dbear
06-04-2004 05:54:49
 Re: Re: what type of cultivator is this in reply to joe, 06-03-2004 20:24:16
We had a couple of edible bean combines that used wooden bearings on the heads. They had grease zerks that we gave a couple of shots every day before use.
joe
06-04-2004 08:39:33
 Re: Re: Re: what type of cultivator is this in reply to dbear, 06-04-2004 05:54:49
thank you i will just grease it then some one had zerks drilled in already
