Lesser Known Classics Discussion Forum
problem with craftsman
Michael Gaguzis
06-02-2004 17:34:19
I just replaced both drive belts. The new drive belt i put on in the rear is 51", the one removed measured 53" (I was unsure if it stretched). Now my variance control has very little play in it which seems to allow less movement in the idler pulley when the brake-clutch is applied, now when i do apply the brake fully and attempt to put it into gear, they grind as if the "clutch" was not engaged. Short story long. My questions is, what actually works as the clutch to allows one to put the tractor into gear? Please help, yard is out of control!
